Hi Bill, thank you for answering. The board works now, so I am all set, but here's how it went:
I have an industrial computer with a passive backplane with 5 LEDs for monitoring +/-5V, +/-12V and +3.3V. The power connectors were such that both AT and ATX power supplies could be accommodated. At first we had an AT power supply (3.3V LED was not lit). When I called the computer manufacturer asking about the problem with the NI board, he immediately said, "So you are using NI boards - we'll need to ship you an ATX power supply". After I installed the ATX power supply (this time, the 3.3V LED was on), the board was recognized by MAX.
I don't remember if in the first case the board was seen as "Other device" in device manager, but I think it was. The boa
rd is PCI-6115 10 MS/s multifunction S Series.
Thanks, -- Sergey.
