Multifunction DAQ
M & E series DAQ cares
Can an E and M series DAQ cards co-exist in the same PC?  If so, how can i install NIDAQ correctly since the E series can only be used with the traditional NIDAQ and the M series with NIDAQmx - - they use different drivers.  Or, perhaps there is a specific version of NIDAQmx that will work with both series cards.
Thanks for any info.
(2,894 Views)
E Series Cards work in DAQmx as well.  Where did you hear that they would only work in Traditional DAQ?
just curious...
Here is a link for you to download the newest (Under Drivers & Updates)
FYI, the readme.html (under Supporting Files on the driver page) has a list of supported devices.
-gaving
(2,891 Views)
