Multifunction DAQ
Logos still using 6001 in Windows 7 64
We appear to still have a case in a windows 7 64 bit system where the NI installation is using ports 6001 and 6002 (which are required by Safenet). The registry update:
HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Logos\Ports\FirstClientPort = 5000
HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Logos\Ports\FirstServerPort = 6010
has already been tried and did not help. The entire program was un-installed and reloaded. This did not help. Is there something special about a 64 bit system? Any other suggestions to free up ports 6001 and 6002
(3,629 Views)
Hi mhubel,
Yes, there is something special about 64-bit Windows: it has a separate version of HKLM\SOFTWARE for 32-bit applications, located at HKLM\SOFTWARE\Wow6432Node. Try setting that one too, if you didn't already.
Brad
Brad Keryan
NI R&D
(3,622 Views)
I am looking at the registry and although there is a Wow6432Node entry, it is at HKEY_CLASSES_ROOT\Wow6432Node, further in that there are entries like AppID and CLSID. Nothing has a \SOFTWARE\ in it.
Do you mean to create:
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\National Instruments\Logos\Ports\FirstServerPort
(3,618 Views)
Accepted by topic author mhubel
Digging a little further I found the entry at
\HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\National Instruments\Logos\Ports
I added the REG_DWORD FirstServerPort
It worked
(3,617 Views)
