Multifunction DAQ
Linux USB-6218 PWR/ACT LED off
Hi everyone,
I recently bought a multifunction DAQ USB-6218 and installed all the software for it (namely, nidaqmxbase and nikal).
When I connect the device to my computer, I don't see the power/activity light blinking like my other DAQ USB-6008.
tog@home ~ $ lsusb
Bus 002 Device 003: ID 8086:0189 Intel Corp.
Bus 002 Device 008: ID 18d1:4ee2 Google Inc. Nexus 4 (debug)
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 008: ID 3923:7269 National Instruments Corp.
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 005: ID 1bcf:2b81 Sunplus Innovation Technology Inc.
Bus 001 Device 004: ID 138a:0011 Validity Sensors, Inc. VFS5011 Fingerprint Reader
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
lsdaq
tog@home ~ $ lsdaq
Detecting National Instruments DAQ Devices
Found the following DAQ Devices:
 Running sudo FWUpdate doesn't list any devices.
Thanks in advance!
Message 1 of 17
(6,713 Views)
Bump. There must be some log file or some firmware update procedure that I'm missing. Any help would be really appreciated!
Message 2 of 17
(6,645 Views)
Hello tog000,
I have a couple questions that will help clarify your setup so that I can help troubleshoot your hardware connection.
  1. Which Linux distribution are you running?
  2. Which version of NI-DAQmx Base do you have installed?
  3. Which version of NI-KAL do you have installed? Please refer to this document to ensure that you have the proper version of NI-KAL installed for your Linux distribution: https://www.ni.com/en/support/documentation/compatibility/17/ni-kal-driver-compatibility.html
  4. Did you experience any errors when installing NI-KAL?  In this case, there should have been an installation error for NI-KAL.
Thank you for the additional information!
Message 3 of 17
(6,632 Views)
Thank you Earl. Sorry for the delay in replying.
  1. Ubuntu 14.04 64bit
  2. nidaqmxbase-3.7.0.iso
  3. NI-KAL 14.0
  4. No errors besides the usual porting of RPMs to DEBs
The DAQ works just fine in OpenSUSE, but I have certain system components that I cannot port. The surprising part is that the cheaper USB DAQ works just fine, but this one (6218) doesn't.
Thanks in advance!
Message 4 of 17
(6,603 Views)
Hello tog000,
Has the device worked properly in any other computer? Has it worked before?
Regards
Ernesto
Message 5 of 17
(6,568 Views)
I have a computer running OpenSUSE 32bit and the device works there.
I verified that the nikal module is loaded in Ubuntu, but there are certainly more NI modules being loaded into the OpenSUSE kernel that I don't see in the Ubuntu kernel. Unfortunately I haven't been able to find which package they come from and verify they are being installed.
Oddly enough, the DAQ USB-6008 works just fine in Ubuntu with the NIKAL driver.
Thanks!
Message 6 of 17
(6,564 Views)
Hello tog000,
Could you please tell me which National Instruments drivers do you have installed in the computer with openSUSE? Also the versions of the installed drivers over there.
Then I will also like to know what are the drivers and the their versions, that are installed in the computer with Ubuntu.
Regards.
Ernesto
Message 7 of 17
(6,545 Views)
Hi Ernesto,
I will get you this information first thing tomorrow.
Thanks for all your help!
Message 8 of 17
(6,537 Views)
Hi Ernesto,
I tried to list packages in OpenSUSE, but I didn't have luck with that, so instead I ran what I had run before:
lsmod | grep "ni"
On Ubuntu:
nikal                 109014  0
ghash_clmulni_intel    13259  0
aesni_intel            55624  2
aes_x86_64             17131  1 aesni_intel
lrw                    13286  1 aesni_intel
glue_helper            13990  1 aesni_intel
ablk_helper            13597  1 aesni_intel
cryptd                 20359  3 ghash_clmulni_intel,aesni_intel,ablk_helper
On OpenSUSE:
nimxdfk               495736  1
nipxirmk              206562  1
nidimk                328434  2 nipxirmk
nimdbgk               381773  3 nimxdfk,nipxirmk
niorbk                100919  4 nimxdfk,nipxirmk,nidimk,nimdbgk
nipalk               1222196  8 NiViPciK,nimxdfk,nipxirmk,nidimk,nimdbgk,niorbk
nikal                 101545  2 nipxirmk,nipalk
aesni_intel            18156  0
ablk_helper            13357  1 aesni_intel
lrw                    13057  1 aesni_intel
aes_i586               16995  1 aesni_intel
xts                    12749  1 aesni_intel
There is a big difference in modules, but I can't seem to find or install them under Ubuntu. Thanks in advance!
Message 9 of 17
(6,527 Views)
Hello Tog000,
I checked and it seems that Ubuntu is not one of the National Instruments supported distributions.
But I was thinking the following links may have useful information for you to find help:
More specifically in:
https://forums.ni.com/t5/Linux-Users/bd-p/5097
and the next link says which distributions are supported.
What Linux Distributions Do National Instruments Drivers and Software Support?
https://www.ni.com/en/shop/software-portfolio/platform-roadmap.html
Good luck with your application.
Ernesto
Message 10 of 17
(6,523 Views)
