Multifunction DAQ
Labview dll returns default values when called from Visual Basic
All,
 I have created a vi to read 4 voltage rails and 2 differerential voltages for current draw readings across resistors. When I run this vi in labview I get the expected results from my UUT. I then setup the outputs on the connect pane and create a dll. When I call this dll from my Visual Basic app, the return values for the current/voltage readings are always the default values (i.e. 0). The dll returns the error code -2491 when call from VB as well.
This section of code is how I declare the dll in VB:
Public Declare Function ReadRails Lib "C:\0714Testset\DLL\GateDriver.dll" _
    (ByRef Current5V As Double, ByRef Current12V As Double, ByRef CTPSU As Double, _
    ByRef FAULT_OUT As Double, ByRef Rail5V As Double, ByRef UUT_SUPPLY As Double) _
    As Integer
I then call the dll using this function:
    error = ReadRails(Current5V, Current12V, CTPSU, fault, vcc, uutSupply)
I have also attached my vi.
Any ideas what causes this?
Thanks!
(3,368 Views)
Hi There,
On the front panel of the VI there is an Array control that is used to specify physical channels on the 2nd of 2 DAQmx Create Channel VIs. This Array needs to be populated in order for the VI to sucessfully run, but currently it's default value is unpopulated and I cannot see a corresponding connector on the connector pane that allows data to be passed into this array when called as a DLL. Could this be the issue here or is there something that I have missed with regards to your issue?
Best Regards,
Ian C
National Instruments UK & Ireland
(3,320 Views)
Thanks for the reply, but I just fixed the problem this morning.
Just looking at my original post and I realize I've posted the wrong vi anyway!
(3,316 Views)
Ah right okay. I'm pleased it's all working. Best of luck with the rest of it.
Ian
(3,313 Views)
