Multifunction DAQ
Labview Data Acquisition
I have a Meilhaus DAQ 1208FS , I want to use a encoder agilent hedl 5540 , i want to find the distance of the encoders travelled .
Can you suggest me how to do it using the digital signals?
Boldness has genius, power and magic in it!'
(4,186 Views)
Accepted by topic author MaveenD
Depending on your specific type of your Encoder youre getting 200-1000 pulses per revolution
(http://de.nanotec.com/page_product_archive__schrittmotor_encoder_heds5540__de.html)
Count the pulses that you get and multiply it by (Pulses per revolution)/360° and you get the current position in degrees.
(4,116 Views)
Thanks dude ,but How to count the pulses without a counter , I have only digital inputs.
Is it possibe to count with the counter?
(4,106 Views)
I wrote a small software timed VI, that will count edges.
Its software timed, so you cant go much higher than 100Hz with the signal.
If you have a counter its a lot faster. Just search for "count digital edges" on ni.com and you will find plenty of examples doing exactly that
(4,065 Views)
Dear Felix ,
Thanks a lot for your reply. Now am able to count the signals . But To find the direction of the encoder from those signals?
Any suggestions i have tried different algorithm ,couldn get good result
(4,054 Views)
Youll have to check the datasheet and find out which impulse you will get or a clockwise or counterclockwise turn.
Then use a case structure to find check if the pulse changed to low or to high
(4,049 Views)
Thanks once again . If channel A leads B it is CCW and viceversa for CW.
I have following this paper , even then my direction is flickering .
http://www.naun.org/multimedia/NAUN/circuitssystemssignal/19-726.pdf
Do you have any idea?
(4,045 Views)
