Multifunction DAQ
Labview 2017 32bit Error-223031
Hi
I have seen this "Internal Software Error" two days in a row. The following is the copy of the error message.
Error -223031 occurred at DAQmx Start Task.vi:7220013
Possible reason(s):
Internal Software Error occurred in DSA software. Please contact National Instruments Support.
Task Name: _unnamedTask<2>
I am running Labview on Windows 10. Don't know if Win10 is the cause or not. Is there a fix for this type of error? I believe I am at the latest driver version
(3,963 Views)
Hello Arthur99
I would like to ask you somequestions.
What is the LV and driver version?
What hardware are you using?
Regards
(3,938 Views)
Hi David22JRA
I am using Labview 2017 32-bit
The driver is up to date.
I am using a PXI-4461 synced with a PXI-4462
Regards
Arthur
(3,931 Views)
Hi Arthur99
Thanks for giving us the information. We would like to know if you are using your own code or if it is an example code.
On the other hand, does that code run correctly before or this is a new code.
Feel free to attach a code screenshot.
Have a great day
(3,922 Views)
Sorry for the late reply.
Yes, the code run correctly before this error.
This is the code screen shot
(3,667 Views)
Hi Arthur,
This post might gain more attention by posting a new thread. It appears this one is several months old. Check out the following link for solutions to a similar issue:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7a7SAC
Best of Luck!
Austin
(3,652 Views)
