Multifunction DAQ
LabVIEW 7.1, RDA Bug?!
Has anyone else noticed the following using LabVIEW 7.1 and RDA (remote data
acquisition)?
Setup one or more RDA devices on the local machine to control hardware on a
remote machine using Traditional DAQ (RDA is not supported with DAQmx).
Create a VI in LabVIEW 7.1 that calls any Traditional DAQ function and save
it. Close LabVIEW 7.1. Double click on the created VI to start LabVIEW 7.1
and the VI simultaneously. What happens on the computers I've tried this on
is that the LabVIEW startup hangs up. I can load LabVIEW and then the VI
but not both at the same time. More importantly, if I build an application
I have the same problem so presently I am unable to build an application
from LabVIEW 7.1 that uses RDA. This does not occur in LabVIE
W 7.0 or
earlier.
Has anyone else seen or not seen this behavior? Are there any work arounds
or bug fixes that anyone knows of? NI Tech support had not heard of the
problem but it is very repeatable for me on all the machines I have tried it
on.
Message 1 of 1
(2,498 Views)
