Multifunction DAQ
LABVIEW 8.2 AND USB-6259
Hi, I am a new user of NI, now I have labview 8.2 in my laptop and I have a NI USB-6259, I want to generate analog signals (voltage) in three channels at the same time with different amplitude, frequency and durations. Can you guys suggest some examples for this? Thank you!
I found some examples under
Hardware input and out put\DAQMX\ANALOG GENERATION\VOLTAGE
they can generate one signal in one channel or two same signals in two channels. But I need to generate three signals in three channels (aoi0,1,2) at the same time.
Message Edited by JHUER on 04-03-2009 09:02 AM
(3,229 Views)
I had to do something similar with a PXI-6713.  I used a Simulate Signal Express VI for each signal and then fed all of them into a single DAQ Assistant express VI.  I have attached a VI that may provide what you need.
For this VI I simulated a USB-6259 in MAX and used that device when I configured the DAQ Assistant VI.
Tell me if this works for you.
(3,199 Views)
Thank you very much and it works great!
(3,169 Views)
