在 01-24-2008 01:55 PM
You may be in luck - we just released DAQmx Base 3.1 for Mandriva; RedHat; SUSE - many users have installed DAQmx Base for Ubuntu -
USB-6008 Linux Ubuntu - has good instructions
Hope this helps, please post back if your run into any issues.
Cheers,
Andrew S
MIO PSE
01-24-2008 06:01 PM - 已編輯 01-24-2008 06:02 PM
DAQmx Base 3.1 requires a different firmware on the 6009's - there should be a utility in the DAQmx Base directory as listed by the error message. If you navigate there, do you have a \bin directory at all? If you have a Windows box with DAQmx, you can switch the firmware to the needed version (DAQmx) - though I realize that can take some time. I'll see if there's anyway to post the utility.
I admittedly have little experience in Linux and none in Ubuntu (which isn't a supported version)- does the device show up at all in the HW profiles? It should be possible to get the PID - what is that value? Also, does the 6211 LED turn on at any point? Another check - make sure you're connecting directly to your computer rather than going through a hub - some hubs don't play nice.
Please post back and we'll see what we can do.
cheers,
Andrew S
01-24-2008 06:02 PM - 已編輯 01-24-2008 06:07 PM
在 01-24-2008 09:37 PM
Of course I should offer the disclaimer that Ubuntu is not officially supported by any NI software product (at least that I know of), and as a result we have done zero testing with NI-DAQmx Base on that distro. So, we can offer suggestions for any problems you run into but can not guarantee that anything will work. I would strongly suggest that you move to a supported distro if possible. NI-DAQmx Base 3.1 officially supports Red Hat 4/5, SuSE 10.2/10.3, and Mandriva 2007/2008.
Hopefully this helps-
在 01-25-2008 02:07 PM
01-25-2008 02:34 PM - 已編輯 01-25-2008 02:36 PM
在 04-02-2008 02:47 PM
