Multifunction DAQ
Is it possible to synchronize different modules using the CompactDaq system?
I need an analog signal and three QuadEnc signals to be measured simultaneously. Is it possible to use the cDAQ- 9172?
What modules do I need?
Thanks for Your help.
(3,043 Views)
I'm Sorry... I read a bit more in the forum and now I know that the synchronization works.
But still I need to know if it is possible to read 3 QuadEnc signals. I have doubts because the cDaq only has 2 Counter/Timers..
Regards
(3,039 Views)
The cDAQ System has only two Counter/Timer, and so the maximum number of encoders you can use is two.
You could use a Counter/Timer board (PCI/PXI-660x). These boards have up to 8 counter on a single PCI/PXI board.
(3,026 Views)
