Multifunction DAQ
Iproblem in software
I developed adative filter software using labview 8.5 for 50Hz noise removal, software removes 50Hz , but problem is that it also changes the shape of input signal what is solution of this problem
(3,163 Views)
Hello discussion forum,
I have some questions about your application.   First, what kind of signal are you acquiring in the first place?  What frequencies are in the signal, excepting the 50 Hz noise?  Second, exactly how are you setting up your filter?  What VI's are you using?  Could you post the filter code by itself?
Knowing these pieces of information would be very helpful in diagnosing your issue.
Dan King
(3,147 Views)
