Multifunction DAQ
Internal callibration data not present
Hi all
I recentlly installed DAQmx v8 from the ni site
Im using three 6115 cards in a PXI chassis.
Ive developed some software to measure voltages
problem is my callibration is messed up now. All measured values are offset
How do I perform the  external callibration on the ai channels on the three cards.
regrads
peter
(2,847 Views)
Hi hwpeter,
I have being looking into your problem for you.  I have done some tests on the PXI 6115 and there were no obvious errors.  If you could send me some example code that I could try out on DAQmx 7.5 and 8 where you saw the problems or some screen shots showing the offset.
What programming environment are you using and what operating system are you running it on.
Seamus
(2,815 Views)
