I'm using SCB-68 with PCI-6221 DAQ card. I'm trying to measure:
1. Voltage due to a load cell, and
2. voltage across 1ohm resistor (basically current flowing) in a circuit where a motor is connected to a controller card.
Both of the measurements are being taken as differential inputs.
As soon as I enable the controller card for the motor, the voltage reading for the load cell shoots to an arbitrary (but fixed) value. I've cross-checked that the problem is not with the load cell as the same phenomenon was observed for a DC power supply too. I've no idea why this is happening. Can somebody help me get over this. A possible reason might be of the signal source type, but I tried using floating signal type for the load cell and grounded signal for the resitor voltage, and vice versa, since I'm not quite sure if the sources are floating point or grounded.
Waiting for response.
Varun
