Multifunction DAQ
Intel MacBook Pro / USB-6009
I am having trouble getting the USB-6009 to be recognized by NI-DAQmx Base's lsdaq.app.  There is no hardware that shows up.  The 6009 is connected and the light is blinking.  The version of DAQmx Base is 2.1.0.
The C code within "NI-DAQmx Base/examples/ai/"compiles fine with the given make script.  When I try to execute the programs, I get the follow error:
ras-computer:/Applications/National Instruments/NI-DAQmx Base/examples/ai rsriprac$ ./acquire1Scan
LoadRuntime: MainBundle
CFBundle 0x304010 </Applications/National Instruments/NI-DAQmx Base/examples/ai> (executable, loaded)
_CompatibleWithLabVIEWVersion: linkedAgainst: 08208002
_CompatibleWithLabVIEWVersion: result= false, mgErr= 1, theActualVersion= 00000000
_CompatibleWithLabVIEWVersion: linkedAgainst: deadbeef
_CompatibleWithLabVIEWVersion: Reseting Linked Against
_CompatibleWithLabVIEWVersion: result= true, mgErr= 0, theActualVersion= 00000000
com.ni.LabVIEW.dll.nidaqmxbaselv
CFBundle 0x312000 </Library/Frameworks/nidaqmxbaselv.framework> (framework, loaded)
<CFURL 0x3116c0 [0xa08071c0]>{type = 15, string = file://localhost/Library/Frameworks/nidaqmxbaselv.framework/, base = (null)}
Macintosh HD:Library:Frameworks:nidaqmxbaselv.framework
2006-11-13 21:32:50.352 acquire1Scan[457] CFLog (21): Error loading /Library/Frameworks/LabVIEW 8.2 Runtime.framework/resource/nitaglv.framework/nitaglv:  error code 4, error number 0 (no suitable image found.  Did find:
        /Library/Frameworks/LabVIEW 8.2 Runtime.framework/resource/nitaglv.framework/nitaglv: mach-o, but wrong architecture)
DAQmxBase Error: <err>Device identifier is invalid.
Here is my hardware information from the "About this Mac":
  Machine Name:    MacBook Pro 17"
  Machine Model:    MacBookPro1,2
  Processor Name:    Intel Core Duo
  Processor Speed:    2.16 GHz
  Number Of Processors:    1
  Total Number Of Cores:    2
  L2 Cache (per processor):    2 MB
  Memory:    2 GB
  Bus Speed:    667 MHz
  Boot ROM Version:    MBP12.0061.B00
  SMC Version:    1.5f10
USB Bus:
  Host Controller Location:    Built In USB
  Host Controller Driver:    AppleUSBUHCI
  PCI Device ID:    0x27c9
  PCI Revision ID:    0x0002
  PCI Vendor ID:    0x8086
  Bus Number:    0x3d
NI USB-6009:
  Version:    1.00
  Bus Power (mA):    500
  Speed:    Up to 12 Mb/sec
  Manufacturer:    National Instruments
  Product ID:    0x717b
  Serial Number:    0123268F
  Vendor ID:    0x3923
Thank you,
-Ram Sripracha
Message Edited by rsriprac on 11-13-2006 11:46 PM
(3,358 Views)
Also no devices show up in the 'lsdaq.app' program.
(3,345 Views)
Hi Ram -
If the device's light is blinking and it doesn't show up in lsdaq, odds are it has the wrong firmware on it.  KB 3NE7GJNY explains how to switch it, which requires a Windows machine.  In this case, you'll be putting on the DAQmxBase firmware, not the DAQmx version.
David Staab, CLA
Staff Systems Engineer
(3,331 Views)
This was not the problem.  The thread continues at:
http://forums.ni.com/ni/board/message?board.id=250&message.id=12003&page=2
Message Edited by rsriprac on 11-19-2006 02:49 AM
(3,306 Views)
