Multifunction DAQ
Increasing DAQ impedence to measure current.
I wish to increase the impedance of my circuit which incorporates the DAQ. I understand that the impedance is 144kOhms, is it possible to place a 10MOhm resistor is series and a 100kOhm in parallel? I wish to measure currents of the order 10nanoAmps to 1microAmp where the voltage will exceed 20Volts if a spike occurs.
(3,304 Views)
Hi there,
If you let me know what specific DAQ device you are using I can look into this issue further.
Way S.
NI UK Applications Engineer
(3,276 Views)
Thank you for your reply,
I have the NI USB-6008 12-Bit, 10kS/s Low-cost Multifunction DAQ.
Andrew Sheldon
(3,275 Views)
Hi Andrew,
The USB 6008 can only only measure voltages up to +-10 V with respect to ground on its analog inputs in single-ended mode. In differential mode however, you can measure up to +-20V in the +-20V range.  You can add any external circuitry outside of the 6008 to condition the input signals. Refer to the manual for more specifications on the 6008:
Way S.
(3,249 Views)
Thank you very much for your help.
Andrew Sheldon
(3,246 Views)
