Multifunction DAQ
Incorrect AMUX/PCI6025 readings using Labview/DAQ
I have an AMUX64/PCI6025. Using my DVM, I measure the voltage at the AMUX screw terminals on various channels with correct readings obtained. Performing measurements with Labview/DAQ are incorrect. What is causing this?
(2,618 Views)
Hello;
The first thing to double check is if the input mode is set accordainly with the connections made.
The best bet is to revisit the AMUX Users Manual and double check the connections you made with the ones shown in the manual. Furthermore, go to MAX and check the input mode of the DAQ device.
Everything must match.
In case you got everything accordainly with the manual, and you still see the same behavior, the problem is probably hardware related.
Hope this helps.
Filipe A.
(2,618 Views)
