Multifunction DAQ
IMTEC T3012 driver
Hello ! I am the unfortunate owner and user of a good quality DAQ board from IMTEC. The T3012 DAQ board is a dual channel, 12 bits, high speed (up to 30 MHz sampling rate)A/D converter, with on-board segmented memory. I intend to develop an experiment using this DAQ board under the Labview environment. But the IMTEC company somehow vanished from the electronic scene. I managed to buy a Labview library for the T3012 and I was so far quite happy with it. But it turned out that this library, probably issued around 2000, is derpieved from certain (but essential) VIs present in a former version (around 1998). Of course I don't have it. If someone ever possessed it and is willing to sell it or whatever, I would be VERY happy ! For the "initiated" ones, the IMTEC_GetTimeStamp VI is the one missing in the latest verion of the IMTEC Labview library I purchased.
Thank you very much !
Nicolas GINET
(3,236 Views)
Nicolas-
In case you still need that vi, I might be able to help you. I'm using the T112 boards by IMTEC (grrr) and also looking for working vi's to support mulitple cards.
Anyway, there should be an explanation of the controlling dll's functions in your user's manual. If you can find the GetTimeStamp function there, you can try creating your own vi that uses "Call Library Function Node.vi" to access the dll's functions. This worked for me with antoher function I didn't have.
By the way, have you found someone who still distributes any sort of code for the IMTEC boards? We now only have a very expensive pile of junk here since we upgraded to Windows XP...
Adrian
(3,177 Views)
