Multifunction DAQ
I need the AMP part numbers of the connectors you use on the 6704 and 6025E boards as I am planning to use 1:1 cabled from NI boards to my boards.
I am designing a manufacturing test system. I simply need the PC mounted connectors to match those used on these boards so that I may use 1:1 cables for the interconnection.
(4,164 Views)
Edwin,
There is actually a Knowledge Base that talks about PCB Mounting Connectors for Boards and also for Cables. You can take a look at it if you go to ni.com and then make a search for "board mating connectors".
As you will see in that KB, the one used for E-Series Boards is the 68-Pos Inverted Right Angle PWB-Mount Connector (Male), with Part Number 760999-01.
Good luck with your system.
(4,163 Views)
honda tsushin kogyo co., ltd.
P/N PCS-E68RLMD!+
This took some doing, but this is the exact same part that they use right down to the stamped part number on the outside of the connector.
(3,328 Views)
