04-28-2009 02:29 PM
Hi everyone,
I'm currently working on a design project which I need to pick a data acquisition card that meets the output of the amplifier. I'm building a force sensing system which I have picked the following as sensor and amplifier:
http://content.honeywell.com/sensing/sensotec/pdf_catalog08/008834-1-EN_Model_UV%20Bridge.pdf
http://content.honeywell.com/sensing/sensotec/pdf_catalog08/008638-1-EN_Model_53.pdf
Please recommend me which data acquisition card I could pick. The only requirement I ask for is having an overall uncertainty below 0.1%.
Thanks for anyone who can help up
Solved! Go to Solution.
04-29-2009
04:15 AM
- last edited on
03-19-2025
09:01 AM
by
Content Cleaner
Since your amp has -3db at 7kHz and you need only 10bit for 0.1% nearly any card with will do. USB-6009 is the lower end. USB 6210 the next step.
So take a look at other boundary conditions: Do you need it calibrated ? (Is there a QM dep. that might ask questions?? ) Space?, EMC/Noise , differential input,
Take a look at the USB-9237 with a build in bridge conditioner ...
04-29-2009 08:23 AM
Many Thanks to Henrik.
I assume this card has the feature to record the input as the function of time, and that's all that i want from the Data Acquisition Card.
Thanks again = ) you help a lot .
