Multifunction DAQ
I look for a DAQ card which can measure 100V pulsed signal in injector solenoid. Is there a one?
I am looking for a card to measure pulsed output from ECU to injector solenoid(inductive) which may go upto 100V & current range of 10A.
Also is there a card for measuring 24V level PWM signal @ around 6KHZ.
(2,874 Views)
Have you considered the NI 407x FlexDMM/isolated digitizer family? You may need an external shunt to measure 10A, but measuring a 100V transient should be no problem, if it's not too fast.
Chris
(2,862 Views)
