Multifunction DAQ
I don't find NI-DAQmx Base configuration Utility
I just buy NI USB-6008 and I want to configure it to adquire analogic data. I don't find the NI-DAQmx Base configuration Utility!!. I need create new Task, but I don't find that option. Please, a little help, thank very much for it. Umm, Yes, I am a beginner in this.
Mensaje editado por JVHKNELLER
(3,012 Views)
Hi JVHKNELLER,
the question is which version of NI-DAQmx you have installed on your PC. Because if you have a version 7.5 or later, you don't need the Configuration utility of NI-DAQmx Base.
You can install any NI-DAQmx (NOT Base) version later then 7.5 and you can use your USB-6008 directly from MAX.
Follow the explanations of this document to use the MAX Tools (Test Panel, Task creation...):
Regards.
MarcoC
(2,983 Views)
