Multifunction DAQ
I am running the example "/labview6/examples/daq/counter/measured buffered pulse.vi" When I run this program, the mouse is jammed.
I am using Labview6 with PCI662E card. When I press run with the mouse on the vi menu, the mouse is jammed and I cannot stop the program unless I reboot the computer. Is there a way to interrupt the program without rebooting the computer? Does any one know why this happens? I appreciate your help. Thank you
(2,798 Views)
This problem had been reported in a previous version of NI-DAQ. It results from running the VI without any external connections, specifically the required gate signal. However, the behavior that causes the mouse to freeze has been resolved in NI-DAQ 6.9. You can download it from:
http://www.ni.com/softlib.nsf/
Erin
(2,798 Views)
