07-25-2005 10:11 AM
07-27-2005 04:25 AM
Hello!
The information provided was a little bit short in order for me to answer you correcly.
Which board are you using? Do you use a M-series device, USB device or a E-series device? Which 'built-in' frequency generator are you referring to?
Thanks for you cooperation!
Jimmie A.
Applications Engineer, National Instruments
07-27-2005 04:30 AM
07-27-2005 08:33 AM
You can generate a frequency by using a counter in pulse train generation mode or by using the frequency generator circuit.
My problem is that i would like to generate a pulse train but without using the counters. I need the counters for other things.Is it possible to use the
frequency generator circuit or do i need to use the counters?
regards
/josef
07-27-2005 09:09 AM
Hello!
The function calls in DAQmx and DAQmx Base should be pretty much the same so I think you can look at the C-program found on this link:
At least you will get the overall programming flow.
Hope this helps!
Jimmie A.
07-27-2005 09:13 AM
