Multifunction DAQ
How to use simple NI-DAQmx C API in .NET, C#
Hi everyone!
I thought to share the solution for the subject with people like me, who are already familiar with the DAQmx driver and want to use it in .NET, C#. Its quite simple, you only need to import the DAQmx functions you want to use from the "nicaiu.dll", and take care for the parameter types. Thats all. So what I have is this (it only contains the main functions and constant variables I have ever used, but any other function can be imported in the same way).
(13,091 Views)
Hi TarPista,
Thanks for sharing your experience. You can see an usefull knowledgebase Programming NI-DAQ in Visual C# .NET on how is possible to use DAQmx with .NET.
National Instruments provides a native .NET API for NI-DAQmx. This is available as a part of the NI-DAQmx driver, just install it manually (Do I need Measurement Studio to use NI-DAQmx in .NET).
Cheers,
Stefo
(13,060 Views)
Thanks Stefo, I didn't know that! I will check it!
Cheers,
TarPista
(13,051 Views)
