Dan,
In order to set up a digital pause trigger, you must set the
Pause.TrigType property to Digital Level, the Pause.DigLvlSrc property
to the PFI line you want to use, and finally the Pause.DigLvlWhen
property to either high or low. What do you mean when you say "I can't
select this as a property?" Is it greyed out? Perhaps you should try
starting with a shipping example. Please have a look at Cont
Acq&Chart Samples-Int Clk-Pause Trigger.vi available in the NI
Example Finder (Help->Find Examples). It can be found by searching
for "pause." Please let us know if you are not able to get this example
up and running.
Good Luck!
Ryan Verret
Product Marketing Engineer
Signal Generators
