10-03-2007 11:22 AM
10-04-2007
07:31 PM
- last edited on
09-16-2025
03:59 PM
by
Content Cleaner
Hello mhfrancis,
Thanks for contacting National Instruments.
Normally, Burst Timing with an Imported Clock is used to configure the Burst Handshaking Mode on a Device. Searching the LabVIEW help for Burst Handshaking, I found that three signals are required. If you refer to the LabVIEW and use the index to find burst handshaking, the link “burst handshaking signals” shows how each of the signals affects the digital input or output. The 6534 Manual has timing diagrams for burst handshaking on page 3-6.
Could you please explain your application in more detail? I saw in your other post that you are looking to synchronize all 8 devices with an external sample clock and a trigger. Is this trigger going to be used to start the acquisition on all 8 devices at the same time? How does the data not line up with the trigger pulse?
Please post back with more information.
10-05-2007 04:32 PM
