Multifunction DAQ
How to share dynamic data using shared variables?
I need monitor data acquired from DAQ and i want to monitor this data from multiple PC´s... I readed shared variable is an option to share data, but it works with dynamic data? If does, how works it?
(4,681 Views)
I don't think network published shared variables work with the Dynamic Data Type.  You need to convert to a real data format, like Array of Double.
(4,661 Views)
Hi andcp360!!
Thanks for using National Instruments Discussion Forums!!  Just like crossrulz stated, network shared variables do not support dynamic data.  However, there is a community example that converts dynamic data (from a DAQ Assistant) to variant in order to be able to use network shared variables.
Pass Dynamic Data from an Express VI Through a Network Published Shared Variable
Hope this helps!
Regards!
Anuar R.
National Instruments México y Latinoamérica
Ingeniería de Aplicaciones
www.ni.com/soporte
(4,655 Views)
Gracias!
(4,650 Views)
