Multifunction DAQ
How to separate the numbers in a string?
I got a string that contains many numbers, how can I separate them?
I've tried to use unbundle, but it doesn't work
(3,118 Views)
Accepted by topic author 123321123
What does your question have to do with DAQ?
You don't have a string there at all. It looks like an array of clusters. Before the unbundle, did you use the Index Array function?
Not recognizing basic data types indicates that you are just beginning LabVIEW. You should at least have taken one of the free on-l line tutorials.
(3,113 Views)
