Multifunction DAQ
How to programmatically (daqmx) configure my pxi-6115 with analog trigger and AI channel terminal as source
I have two boards of pxi-6115 (synchronized) and want (at least) to use the first one as trigger source. With the possibility to both have analog and digital trigger (once at a time). When I use analog trigger I want to select one of AI channels terminal and with dig. trigger the PFI 0-terminal.
What is the AI channels-terminal called in the list (I/O terminal) for this 6115-board.
Another trigger related question :
Do I have to use both a start-trigger and a reference trigger node if I want to have pretriggsamples?
Kind regards
Oddgeir
Message 1 of 1
(2,952 Views)
