Multifunction DAQ
How to programatically get an array of availble clock sources for a device
Does anybody know how to get an array/list of all available clock sources programatically in C/C++.  I know in LabView if you drop the control on the front panel it is already populated with the available sources.
For instance to get the available channels in C you would call DAQmxGetDevAIPhysicalChans.  Is there a similar function or any other way of doing the same with Clock sources.
(3,504 Views)
Hello wewe,
I am unable to find a function that can accomplish this at this moment.
Here are some examples and information that I can find on configuring clock sources, maybe they can give you some clues
Check out the "Configure the Timing Parameters" section of this white paper:
https://www.ni.com/en/support/documentation/supplemental/21/using-ni-daqmx-in-text-based-programming...
NI-DAQmx timing section of this doc:
https://www.ni.com/en/support/documentation/supplemental/06/learn-10-functions-in-ni-daqmx-and-handl...
Joel C
(3,487 Views)
Thanks for the info Joel.
Have you found anything yet.
(3,471 Views)
Hello wewe,
I have been unable to find such a function. This might be the best you can get:https://www.ni.com/docs/en-US/bundle/ni-daqmx-c-api-ref/page/mxcprop/attr2996.html
Maybe this is one of those things LabVIEW excels at.
Joel C
(3,450 Views)
