Multifunction DAQ
How to perform direct (non-buffered) Analog Input reads on a PCI-6035E?
I would like to bypass the onboard FIFO and perform a direct read on a given Analog Input channel on a PCI-6035E card.
(2,517 Views)
Dan;
The only way to bypass the FIFO is by doing a One Point Analog Input operation. That sort of operation is completely Software timed, so, if you need a high rate acquisition, that is not a good option.
Anyway, if you really need to do that, you can use the One Point analog input VIs and have that one on a loop. So, at each iteration of the loop, you will acquire one point only.
Hope this helps.
Filipe
(2,516 Views)
Filipe,
Thank you very much for your response. But unfortunately the VIs are not available to me. I am writing my own register level driver for Win2K using RTX (from VenturCom). I believe what I need is the register level equivalent to the 'One Point Analog Input' operation, but I have yet to come across it in any of the register level manuals. I've eMailed the question to NI, but they don't support register level programming. Any ideas?
Dan
(2,516 Views)
