03-06-2009 02:30 AM
03-10-2009 06:34 AM
Hello Sam,
It is possible to measure frequency much faster then every 20ms. Probably the problem in your case is related to how much samples you bring at which rate to the Tone Measurements express vi. If you want it to give out a new value every 20ms, it is necessary that you bring it a new block of data every 20ms.
Let's start with the code you have at this point and the type (frequency?) of the signal which you want to read.
Kind Regards,
Wouter
NI Belgium
