08-29-2005 06:20 PM
I have written a DLL that utilizes the DAQPad 6015. The DLL is a part of an extensive application. The application is planned to be deployed on many computers. Is there a way to include only certain files from the DAQPad 6015 Installation CDs in the application installer, instead of having to separately install the DAQPad driver (from the CDs) on every of the mentioned computers? If yes, what is the list of files? Any help on this subject will be appreciated a lot. Thanks in advance.
Sincerely,
Bogdan
08-30-2005 05:07 PM
Hello Bogdan,
One thing you could do is a silent install of the DAQ driver. You can look at this KB about silently installing NI-DAQmx, if that is the driver that you developed with. You can make a batch file to run multiple installers at the same time. If you used LabVIEW to make your dll you can look at this KB.
I hope this helps you get started!
Laura
