Multifunction DAQ
How to get a 15 pin analog output to BNC
Hello all,
First time posting here.
In out lab we have a Biodex 3 (here is the new version, it is basically the same thing: http://www.biodex.com/physical-medicine/products/dynamometers/system-4-pro-0).  It can output the analog position, velocity, and torque data from the machine to be collected in other data acquisition software.
I need to get this analog data, which comes from a 15 pin two row female connector on the back of the machine (see section 6-3, towards the bottom.  http://www.biodex.com/physical-medicine/products/dynamometers/system-4-pro-0).  I need to get this output so that I can plug it into our NI A/D board via BNC connectors.
I have no idea where to even begin.  Do I need to make a breakout box of some sort?  I've seen 15 pin to BNC connectors for tv signals, but those only give 8 BNC outputs and so my worry is not knowing what pin is associated with what output.
Any help is much appreciated.  Thank you.
(3,524 Views)
I doubt that you will be able to find a break out box with your unique connections. You could have your own made or use a matching db15 with solder cup connections and manually wire to three bnc connectors where the signal is the center conductor and gnd is connected to the shield.
(3,521 Views)
Yea dude, head to digikey.com and buy a roll of RG174, some BNC crimp ends and a crimper, and a DB15 solder-cup connector and a backshell. Fire up the soldering iron, crack open a beer, and build a cable.
Draft the schematics/pinout first, wire it up, ohm it out, and plug it in.
If you're not up for doing it yourself, companies like L-Com can do custom cable assemblies for you.  Still need to do the design for wiring specs and pinouts.
(3,518 Views)
