Multifunction DAQ
How to get 5V out of NI USB 6501 from +5 v source
Hi All,
I have NI-USB 6501 DAQ board, I have an issue that when I plug the usb board in my desktop usb, and measure 5V pin source I dont get voltage output from that pin. its 0v
Is there any settings required to enable the +5V voltage source.
How can I turn on the 5V source in NI-USB 6501
Please let me know
(5,307 Views)
Accepted by topic author AnkitG
You don't have to do anything to turn it on. What two pins are you connecting to when you take the measurement?
(5,287 Views)
I use GND and the pin which says +5 V, there are two +5v pins I tried both and even tried different computer USB port.
(5,283 Views)
Problem solved I can  now just use one of the output channel with open collector settings  I can get now around 4.8 v ~ 5 V, the +5 V source output just gives floating numbers.
(5,248 Views)
