Multifunction DAQ
How to generate an output waveform and a pulse
I want to generate a waveform and a pulse with LabView and PCI-MIO card.
The waveform must be a sine with a frequency of 1 Hz and sampling frequency 10 Hz. The pulse must be a square signal between 0 and 5 V with frequency of 10 Hz. Every point of the sine waveform must be synchronized with every point of the pulse. The pulse is used as a trigger for a digital camera.
I have been looking at the DAQmx examples but I haven't succeeded.
Any comments on the best way of doing this?
(2,908 Views)
Hi Raimon,
Look at attached VI,
Here i am first building 2 waveforms sine and square of 10 hz, 0-5V and generating them on ywo analog output channels.
You can use the logic of creating the two singals and for AO generation that i have shown in this VI.
If you want AO to be regenerative/non regenerative, find the relevant  example AO generation VI's, modify it to generate functions generated by my VI and go ahead.
regards
Dev
(2,900 Views)
