Multifunction DAQ
How to flash a Rabbit processor through Labview
Hi all
I need to flash the Source code for the rabbit processor from labview.
Rabbit processor number is 3400 and can any one guide me in downloading the source file(.bin file) from labview
Bala
(3,357 Views)
Hi Bala,
First off, if you have a digital output board/card, you can create your own program in LabVIEW that has the capability of downloading your source file to your target.  You would basically do whatever handshaking is required by the processor in order to start clocking the source file into flash.
However, unless you are extremely well versed in the protocol required to download your source file, I would recommend using the utility made by Rabbit Semiconductor that they design for this purpose.  I don't know which exact utility that would be, but you can contact them and request more information as to what utility is needed.
I hope this helps,
Kevin S.
(3,322 Views)
