Multifunction DAQ
How to compute USB-6009 Max Sample Rate with AO and AI
The USB-6009 Spec Sheet indicates the AI has a max 48kS/s aggregate sample rate.  The AO can be updated at 150Hz. If there is one AI configured and one AO configured, what is the max sample rate available for the AI?  Is it 48kHz, 48kHz/2? Do the AO channels impact the AI aggregate sample rate?
(1,141 Views)
The AI and AO are two separate systems. They have their own ADC/DAC.
https://tmesystems.net/
(1,128 Views)
Though there is no hard and fast limit, the USB bus traffic could create a bottle neck based on what other peripherals use the same USB hub at the same time.
Santhosh
Soliton Technologies
(1,110 Views)
