Multifunction DAQ
How does one un-register a callback?
I want to be able to change the number of samples associated with my EveryNSamples callback/event. If I try, however, to register the event again, with a different value for the nSamples argument, I get an error message stating that the event is already registered, and that I should un-register the event first.
How does one un-register an event in DAQmx? I don't see any function to do this in the documentation. I'm using DAQmx 8.8 at the moment.
(3,657 Views)
Hello Vijay,
In labVIEW you can use Unregister for event.vi in DAQmx advance pallete, in C you can use DAQmxRegisterSignalEvent function and pass a NULL value for the event callback function pointer.
Note: You cannot register or unregister an event in NI-DAQmx while a task is running.
Note: Refer to the Asynchronously Reading and Writing with the NI-DAQmx Visual C++ Class Library topic in the NI Measurement Studio Help for information on unregistering events in the C++ API.
Cheers
NIyer
(3,638 Views)
Thanks for reply. I will try this shortly when I have a chance. I am working with the C API. You suggest using the DAQmxRegisterSignalEvent() function to unregister an event. However, if the event was registered with the DAQmxRegisterEveryNSamplesEvent(), shouldn't I just re-use that function with a null pointer to unregister the event?
In any event, will try this weekend.
Vijay
(3,628 Views)
