Multifunction DAQ
How do you obtain high impedence on digital output line?
I would like to switch between logic zero and high impedence on the digital output lines of a 6115. However, there are pullup resistors that prevent the output from floating.  Is there a way around this? Ideally, negligible current will flow through devices connected to the digital output lines when the output is tristate, high impedence.
(3,227 Views)
Hi Dekay,
I pulled this from the S Series Help
Each line has a weak pull-up resistor connected to it, as described in the specifications document for your device.
It sounds like you want to simply switch your lines from an output with logic 0 to an input which will have a high-impedance state.
Maybe if you tell us more about what it is you are trying to do we could give you some better details.
(3,213 Views)
Hi!
   You should be able to do it in max, in device configuration.
   If you're programming in CVI, have a look at this function:
    DAQmxSetChanAttribute (, "", DAQmx_DI_Tristate, );
   (see help for further details....)
   Hope it helps!
graziano
(3,207 Views)
Otis -
I would like to use the digital lines to selectively create or eliminate a ground path. I have a resistor with one end connected to DIO0 and the other to a circuit in which I would like to change the resistance. Switching between DO0=0 and DI0=high impedance was expected to put the resistor in the circuit or take it out, but it still puts 5V out on DI0 when in hi-z.  A program sample is attached.
(3,199 Views)
Hi Dekay,
Instead of creating a Digital Input Channel on the same line as the Digital Output Channel, just use a single Digital Output Channel and use the DO.Tristate property to tristate the line. Your code has two tasks sharing the same line. Let us know if this helps.
Michael P
(3,174 Views)
