Multifunction DAQ
How do I trigger multiple counters in VB?
I am using a 6608 card to measure frequency by counting a certain number of periods from my source and comparing that to the count from the 80MHz clock. My accuracy is not what it should be, because I haven't figured out how to trigger both counters simultaneously. I know I need to use a hardware trigger and the select_signal function, but I'm having trouble figuring out the exact function calls. Is there any code samples out there in Visual Basic that shows how to do this?
(2,757 Views)
Hi Nate!
The function that you are looking for is GPCTR_Change_Parameter with paramID = ND_Start_Trigger.
For an example, you can take a look at the: Program Files/National Instruments/NI-DAQ/Examples/VBasic/TIOgenSquareWaveStartTrig.vbp.
Hope this helps.
Erin
(2,757 Views)
