Multifunction DAQ
How do I format a 2 dimensional array?
I am using LabVIEW 7.0 and trying to format a 2-D table such that I have one column that records the date and time (d/t) every second and the other columns for corresponding channels' temperature readings. Right now, I have a column for the d/t for each channel. I don't need a column for the d/t for each channel because it would be redundant for each channel to show the same d/t reading. So, how do I get one column with only the d/t and the other columns with the temp. measurements?
thanks...
(2,536 Views)
Hello Jon411,
I have attached an example program attempting to do what you are describing. I wasn�t exactly sure how you were acquiring your temperatures, so I just used random numbers. Hopefully this will provide at least an idea of what you are trying to do.
If none of these suggestions help, or if I�m not correctly understanding your issue, please post the software and versions you are using, the applicable portions of your code, and any other information that may help, and I�ll be happy to look further into it.
Have a nice day!
Robert M
Robert Mortensen
Software Engineer
(2,536 Views)
