Multifunction DAQ
How come I can only import cDaq devices into NI MAX (that I have saved in a config file) as simulated device and not actual devices?
How come I can only import cDaq devices into NI MAX (that I have saved in a config file) as simulated device and not actual devices? Is there a way to make them not simulated?
(4,252 Views)
Hello Breaker,
I went ahead and try the export and import configuration my MAX. I found out that the only way it is possible to import your cDAQ device in MAX is by having it connected, with the exact same modules configuration from the previous configuration. Please give it a try with the module 1 connected to slot 1, module 2 to slot 2 and so on.
This is the right way of importing the configuration into the new computer, as it is shown on the image below.
David M.
http://ni.com/support
(4,212 Views)
