Multifunction DAQ
How can I use PCI-6024E to generate a DC voltage with controllable way?
Right now, my Labview 8.5 is my working platform. Currently, I am trying to use PCI-6024E card (combined with BNC 2110) to generate controllable DC voltage to make one galvo scanning system work, all I did is select DAQ assist--Generate Signals---Analog Out--Voltage, in the configuration panel, I chose 1 sample on command, but only woks on testing mode, when click "finish", no controls can be found from the block panel, can any one help me?
Thanks in advance.
(3,086 Views)
You need to create the control yourself. The wizard generates code - not controls or indicators.
There is an example called Gen Voltage Update (Help>Find Examples>Hardware Input and Output>DAQmx>Voltage Generation) if you want to see how simple the actual DAQmx code is for this.
(3,078 Views)
I figured it out, the "data" is the control I am looking for, but thanks anyway.
(3,072 Views)
