Multifunction DAQ
How can I access the driver DLL,s from Matlab or Java?
I would like to access a DAQpad-6016 from Matlab or Matlab via Java objects or via c-files. Is it any support for that? Is it any DLL-files to download or c-code? \Ake
(3,603 Views)
Hi Ake!
I think the 6016 supports NI-DAQmx. If so, I started a thread
http://forums.ni.com/ni/board/message?board.id=250&message.id=10165
(opens in new window) that explains how to import the NI-DAQmx dll into Matlab.
I'd be happy if it works for your card, too.
Jens
(3,585 Views)
Thank you Jens!
It use NI-DAQmx and i should try your tip and Andreas m-code.
Åke
(3,583 Views)
Hi Åke!
Where did Andreas post his version of the m-code? I cannot find it.
CU
Jens
(3,579 Views)
It could be found at the Matlab file exchange server http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=6970&objectType=file
Or search on "Andreas Kapp"
Åke
(3,572 Views)
