Multifunction DAQ
Hi i'm having trouble connecting my digital signal to a case structure
Hi i'm having trouble connecting my digital signal to a case structure. And i'm also having trouble acquring the 3 signals together, 2 analog(thermistor & potentiometer) and one digital(switch). could you help with that? thanks
(3,730 Views)
Use Index Array to get the first element in your digital array.
(3,721 Views)
I've got problems with the breadboard connection as well, the digital signal which is the switch is acting as an on and off switch for the 2 analog signals. wrong readings when the switch is off & the correct readings when its on. but i want all of them to act independently. how can i do that?
(3,717 Views)
