07-09-2007 08:26 AM
07-10-2007 04:21 PM
Hi Dustin,
Thank you for posting on the National Instruments forums. Parallels is not officially supported by National Instruments, but it is possible that you can get it to work.
The first thing you want to make sure of is that you installed everything in the correct order. Start with installing LabVIEW, then install the DAQmx drivers and finally plug in the hardware. Then I would check is to make sure that the device shows up in the Device Manager as a Data Acquisition Device when you plug it in. If you are able to get it to show up there, then check in the Measurement and Automation Explorer and make sure you can see the device there.
When the device shows up in the Measurement and Automation Explorer, LabVIEW will be able to use the device.
There might be something you have to do in Parallels to make sure that the USB-6009 shows up correctly in Windows, but I am not familiar enough with Parallels to tell you what that is if that is the issue. If you run into any issues with this step, please post them here. I will try to help you, but I can't guarantee a solution.
