Multifunction DAQ
Help to connect USB-6251 to PC
Sorry,  can anyone tell me how to get a USB-6251 connected to my PC.  Device manager sees it but I can't find the drivers.
This is my system setup:
Operating System(OS)                Microsoft Windows XP ProfessionalOS Version                          5.01.2600OS Info                             Service Pack 3Processor                           Intel(R) Core(TM)2 Duo CPU     E8400  @ 3.00GHz / x86 Family 6 Model 23 Stepping 10 / GenuineIntel / 2992 MHzNumber of Processors                2Physical Memory                     1.93 GB of RAMDrive C:\                           136 GB of 149 GB free                                    National Instruments Software:      Version:                                    CVI Run-Time                        8.5.1.356NI-DAQmx                            8.8.0f2NI-488.2 Software                   2.60IVI Compliance Package              3.3LabVIEW                             8.6.1LabVIEW Run-Time                    6.0Measurement & Automation Explorer   4.5.0.49152Measurement Studio                  Visual Studio 2005 Support - See individual versions below.     DotNET                                    Common                    8.5.20.149NI-USI                              1.0.2NI-PAL Software                     2.4.0NI LabVIEW SignalExpress            3.0NI Spy                              2.6.0.49152NI-VISA                             4.4.1     NiVisaServer.exe               4.4.0.49152     NIvisaic.exe                   4.1.0.49152
(3,876 Views)
Sorry about the format of the system setp.  I'll try again:
NI-DAQmx                            8.8.0f2
LabVIEW                             8.6.1
     DotNET
          Common                    8.5.20.149
NI-USI                              1.0.2
NI Spy                              2.6.0.49152
NI-VISA                             4.4.1
(3,873 Views)
It seems as if you have the driver.  The driver that is compatible with your system is DAQmx.  The DAQmx 8.8 readme states that this driver is compatible with the USB-6251.  Are you unable to use the DAQmx API in your application development environment?  Are you experiencing a particular issue?
Sara Lewandroski
Applications Engineer | National Instruments
(3,844 Views)
Hi,  thanks for the reply
You ask:
Sorry, I don't know what that means.
I have solved the problem by installing LabVIEW 2009.  Thanks
(3,842 Views)
