Multifunction DAQ
Glitching phenomenon on DAQ 6062
We are using a 6062 PCMCIA card with Labview to continuously generate a waveform on the AO.
A brief (100 ms) data acquisition is done every 2 seconds on 2 AI.
We use the Daqmx Timing - Daqmx write to write the samples until the vi Daqmx Is Task Done stops generation.
The problem is that we have a glitching phenomenon every second on the AO. (waveform samplig info: Fs= 36000, #s = 36000).
I tried to change the buffer size to 72000 but It did not solve the problem.
(3,807 Views)
Here is attached a picture of what I get on the AO.
(3,803 Views)
I need your VI in order to simulate your problem.
Can you paste it in your next message.
Thanks.
Omar S.
NIF.
(3,773 Views)
The main .vi is b1.vi.
If used as is, the application will need sinusoidal inputs in the 2 AI to run. Once it has done a first search it will loop according to the number of cycles specified.
I suggest:
Frequency= 100Hz
Force: 500N
Trial duration: 10000 cycles
Save every: 5000 cycles.
(3,771 Views)
I suggest you to change your DAQmx Timing function in order to have a continuous samples generation instead of finite samples generation and put your VI configuration outside of the while loop. The glitch phenomenom is due to the actions done in the while loop between the end of your finite samples generation and the start of the next generation sequence.
Use the following example to help you in your changes:
The example is available on C:\Program Files\National Instruments\LabVIEW \examples\DAQmx\Analog Out\Generate Voltage.llb\Cont Gen Voltage Wfm-Int Clk.vi
Hope this can help you.
Omar S.
NIF.
(3,749 Views)
